Interface - Group within record
584 1
Margaret_Picker
The List interface allows for Grouping of fields within records - which makes it visually much easier for users when records have many fields.
Is this available for other types?  I would like it on Record detail but cant make it work.
Margaret
10 - Mercury
10 - Mercury
Hey @Margaret_Picker!
If you are making reference to the type of groups found on the image below, my experience is that you can only create those groups in relatively new interfaces -created since the launch of such feature.
E.g. I have an old base with existing interfaces. If I try to create groups on an existen (old) interface, I am not offered the option ("+ add group" button is not shown). However, if I create a new page/interface I am always offered the option to create groups.
I would suggest you create a new version of your page/interface to achieve this. -Unfortunately, you might need to choose a different layout (other than Record Detail -as it is not available any longer). You might want to choose Record Review instead.
Please let me know if this works for you!
Mike, Consultant @Automatic Nation
10 - Mercury
10 - Mercury
