Interface Element Groups Movement Improvement
1554 3
cvoith
7 - App Architect
7 - App Architect
Hey guys,
I was wondering if anyone had any suggestions for moving elements around more smoothly? At the moment when I try to move record elements in grids they rearrange everything in ways I wasn't intending.
For example: I have a section on my interface for Important Links that are pulled from different fields that I want to lay out in a particular way. And when moving them into positions from this : 
To attempting to get all the elements aligned it does this:
Does anyone now of a way to maybe lock locations of elements or grid or something to just make moving things around smoother?
Joseph_Roza
8 - Airtable Astronomer
Use blank text elements to determine the structure of the 'grid' you're looking for and add your field elements where you want them. Then, if needed, delete the blank text elements.
I'm pretty sure building-by-elements is going away soon, so I wouldn't spend too much time learning how exactly to manipulate them. They're finnicky.
3 Replies 3
Joseph_Roza
Oh man! I hope they don't go away!! That's why we use AT! Everyone needs different views!
Joseph_Roza
I was concerned at first, too, but I'm optimistic. The new system has some kinks to iron out, but the addition of mobile interfaces makes it a pretty stellar change.
