Need Help!: Creating Graph in Interface Designer to Display Column Averages
1737 4
Gerard_Blokdyk
Hello Airtable community,
I've been working on a project where users input data through a form, and the results are recorded in the base. I have set up a rollup field for each question to calculate the average of the results per field. Now, I want to create a graph in Interface Designer that displays all the columns along with their averages in a single graph and sorts them from highest to lowest average.
I'm currently having a hard time achieving this, and I'm wondering if I'm approaching it the wrong way. Could anyone provide guidance or suggest a more effective approach to visualize this data in the Interface Designer?
Thank you in advance for your assistance!
https://airtable.com/appbYmoC5vgmEZJPx/shrZ7wAcVoE0AcfIA
Gerard_Blokdyk
SOLVED: I use Automations to find the rollup records at a scheduled time (since # of automations is limited per plan per month) and update the record in the separate table used for the graph
4 Replies 4
stevendasilva
Thanks Steven, much appreciated!
Is there a way to have all columns in one graph so we can see which has the highest and lowest scores against each other right away. For example, something like this:
Gerard_Blokdyk
stevendasilva
@Gerard_Blokdyk  Awesome nice work!
