Best (and simplest) way to send emails for clients from Airtable
Topic Labels: Integrations
593 0
Afrench
I help multiple clients so the solution I seek needs to be able to work in an environment where I have the airtable base > then I have a client > the client has prospects and customers they need to email.
I'm trying to determine if it's possible to send 1-to-1 emails to prospects or customers for my clients from Airtables without having to setup a secondary email tool (lemlist, hubspot, mixmax, etc) for each client. Can I connect directly to the client's email address? Is there an integration that provides visibility on delivery, opens, and clicks for the emails sent directly from a client's email address?
Sendgrid isn't an option because corporate IT or lack of knowledge on the client side will prevent the emails for ever getting sent out.
I'd prefer not to set up Lemlist (or comparable tool) for each client because it's 1 more login/tool to manage (in addition to the monthly fee)...but if that's the only option I'll make it work.
Any suggestions would be greatly appreciated.
Alison
0 Replies 0
