Grid view Scrolling Issue
Topic Labels: Views
4890 22
Jared_Wright
When I scroll down on a table in the Grid view when I have more records than fit on the screen everything scrolls back up to the top.
See the video below.
22 Replies 22
Donna_Edgar
I’m having the same issue. Is there a fix?
Jeremy_Smolik
Same problem, it’s making Airtable unusable for any lists with more than 15 records. On desktop using mouse wheel, and same problem on laptop with touchpad. It’s the site. Will need to port my lists to Google Sheets just to be able to use my CRT. Ah well, time to find another site.
I’m asked Support and they sent me a code to try to fix it, but it only worked once… Perhaps if everyone asks they may try to work on a solution.
Daniela_Quesada
EXACT same issue here!
Nicolas_Dickins
Same issue. I also asked support and they said it was a tricky one and they would get back to me. Been a week or two now. I hope there will be a fix soon or a workaround (different type of mouse/driver?). Working on Windows 10 with Chrome but confirmed it also happens in Edge unfortunately.
Oooh hopefully they get on to it soon. I’m still waiting for a fix. It is really frustrating!
Rui_Chen
Bumping this one, same issue here!
Ebba
Airtable support - could you please assist with this. I have invested a lot of time into Airtable but am feeling ready to cut my losses and walk away as I am losing so much time due to this issue. We look forward to hearing from you.
Hi @Ebba
I would also send a copy of your yo to Airtable Support: support@airtable.com
Mary Kay
amber_h
same issue, so annoying, emailed support also.
