Automation - integration AT - Box?
Topic Labels: Automations
454 1
Sean_Lake1
8 - Airtable Astronomer
Hello all wonderful AT’ers.
Quick question.
I have entries in Airtable that Box folders are created off from.
110122 - 203.02-Lighting - Cinematic Fundamentals 5.00
IS there a way to have Box folders created with the above format based on the date and course fields?
Of course it’d have to create a main parent folder first of the Client name, THEN the individual date-course folders.
I do have integromat/Make(r)?, in case that helps.
Hi @Sean_Lake1 ,
Yes you can definitely do that in Make/Integromat , including the parent folder
