Calculations within nested IF AND statements?
1316 4
Benjamin_Jones
Hi everyone,
We have updated our service pricing in October and I’m trying to update the calculation for services rendered after 10/1. In the below code {Direct Time} is {Direct TIme} + {Indirect Time}. Is it possible to use calculations like this within a nested IF statement?
(IF
AND(
{FY}=“22”,
{MM}>=“10”,
({Total Time} * {Rate by FY by MM})+{Pass through Materials},
({Direct Time} * {Rate by FY by MM})+{Pass through Materials},
Best,
Ben
4 Replies 4
it seems like something not OK in your syntax
assuming you want something like
IF (Statement1 AND Statement2 AND Statement3) then X else Y,
in your text, there are 4 statements and no X and Y
it should be written as (added more linebreaks to highlight statement part):
AND(
Statement1,
Statement2,
Statement3
X,
Y
Benjamin_Jones
@Alexey_Gusev Thanks, you were correct on the syntax.
However, even with this corrected the calculation does not work. I can return simple text strings, however can’t get it to perform calculation A if the and conditions are met, else B if not.
Ex:
AND(
{FY}=“22”,
{MM}=“10”
“A”,
“B”
^^this works
AND(
{FY}=“22”,
{MM}>=“10”
{Total Time} * {Rate by FY by MM}+{Pass through Materials},
{Direct Time} * {Rate by FY by MM}+{Pass through Materials}
^^ this does not.
  1. Can anyone confirm if it is possible to do conditional calculations?
  2. If not possible could i do the calculations in different fields and create a conditional to pull one of these values based on the parameters?
Benjamin_Jones
And the answer is 1. no, 2. yes.
AND(
{FY}>=“22”,
{MM}>=“10”
{Post 10/2021},{Pre 10/2021})
For numeric comparisons, the numbers that you’re comparing against should not be in quotes. Airtable will sometimes auto-convert strings to numbers for mathematical operations, but it’s not something that should be relied upon.
If {FY} and {MM} are numeric fields (i.e. fields that output numeric values), try this instead:
  AND(
    {FY} = 22,
    {MM} >= 10
  {Total Time} * {Rate by FY by MM} + {Pass through Materials},
  {Direct Time} * {Rate by FY by MM} + {Pass through Materials}
If those fields output strings, use the VALUE() function to convert them to numbers before comparison, like this:
  AND(
    VALUE({FY}) = 22,
    VALUE({MM}) >= 10
This could also be simplified a bit. Because all that you’re changing is the first operand in the “inner” formula—{Total Time} vs {Direct Time}—the overall formula could be written like this (using the second VALUE()-driven version as an example):
  AND(
    VALUE({FY}) = 22,
    VALUE({MM}) >= 10
  {Total Time}, {Direct Time}
) * {Rate by FY by MM} + {Pass through Materials}
