Curl: (60) SSL certificate problem: unable to get local issuer certificate
Topic Labels: API
1499 1
Aliaksei
Hi! Trying to reach Airtable via curl from debian buster.
root@689c6c6a3ea9:/app# curl https://www.airtable.com
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Installed last updates of ca-certificates, tried to reload them but it doesn’t help.
For now it solved when I manually installed SectigoRSADomainValidationSecureServerCA.crt into debian trusted cert store.
Could you please check that issue?
acco
Hey there. Why are you curling the www as opposed to the API endpoint? api.airtable.com.
Do you get an SSL issue when querying valid API endpoints as well?
