Hi there - We are trying to filter records based on multiple IDs but it is doing so in a loop so we can’t use the || or && as we don’t always know if there are multiple and often times there are 5 or more variables.
We want something like this:
var these= tabale_await.records.filter(f_record => f_record.getCellValueAsString(“Term_at_id”) == [any of these])
Here is a re-phrasing to hopefully explain a bit differently:
Table 1 is a list of terms
Table 2 is a list with two columns relating terms from table 1
We want to filter a list of terms from Table 1 and find all the matching pairs in table 2. With what you posted we would have to loop it which we want to avoid.
What is preferred is to have something like:
[any of these from table 2].includes(f_record.getCellValueAsString([any of these from table 1]))
It sounds like either you want to find the intersection of two arrays, or maybe you would benefit from creating an object that hashes a term to all of its related values. Bill French has written extensively about using hashes/maps to avoid loops inside loops.
@kuovonne - I have it partially working. I need it to recall which record IDs from the table with the links, not the individual terms.
Ideas?
var t_links = base.getTable("Table 1")
var t_links_aw = await t_links.selectRecordsAsync
var t_table = base.getTable("Test linking")
var t_table_aw = await t_table.selectRecordsAsync()
var id_peanuts = [] // ids from the linked terms
id_peanuts.push("recfMSt4Dd25XNi1V")
id_peanuts.push("rec5hD3qqvEKDKIfh")
var f_foods = t_table_aw.records.filter(f_record => f_record.getCellValue("Table 1")!=null)
var arr_t1_ids = f_foods.map(recordID => recordID.getCellValueAsString("recordID (from Table 1)"))
console.log(arr_t1_ids)
function intersection(first, second)
first = new Set(first);
second = new Set(second);
return [...first].filter(item => second.has(item));
var first = id_peanuts
var second =arr_t1_ids
var common = intersection(first, second);
console.log("Common elements are: " + common);
When you want to know if “term01” exists in Table 1, you simply test for it - it is instant and no looping:
if (hashIndex["term01"]) {
And if you need to access the record for any given term, you could use the record ID to do so. Alternatively, simply include the data from the record in the hash index and you don’t need to go foraging for the record to know the other attributes of the term.
let topic = hashIndex["term01"].topic;
One of the big benefits of hash indices is performance which for these tests would be measured in single-digit milliseconds.
Probably not without seeing the grand scheme of the requirement. But, there is nothing about hash indexes that tilt toward hard coding. Setting a model that is capable of determining if and where something exists is an indexing challenge; the most elegant implementation that avoids brittle hard coding techniques is really a different challenge.
I always recommend getting it to work in a performant manner first; then make it less brittle and more reusable.
@Bill.French - Here is a sample table. Essentially I am trying to build the equivalent of finding all the menu items // recipes that have peanuts in them.
Hi - They don’t need to be ranked, and weights aren’t important. I am trying to avoid a loop (with the type of peanut foods for example) within a loop (all the recipes).
I’d like to have it spit out all the recipes with all the types of peanuts all at once.
The code below would work if I had an efficient way of mapping all the values from the table into keys.
var data = [{"id":"123","color":"Red","model":"Tesla"},{"id":"124","color":"Black","model":"Honda"},{"id":"125","color":"Red","model":"Audi"},{"id":"126","color":"Blue","model":"Tesla"}]
var keys = ["color", 'model'];
var values = ["Tesla", "Audi", "Red"];
var result = data.filter(function(e) {
return keys.every(function(a) {
return values.includes(e[a])
console.log(result);
Yes, it’s outlined in the article. The premise is simple - loop through all records of the table to generate JSON objects based on keys before performing the logic that uses the index. This typically takes a second or two and has the added advantage of removing duplicate keys. You are left with a clean index to perform single-digit millisecond lookups.
