Gmail automation with a lookup field as recipients
Topic Labels: Automations
2383 8
Jose_C
Hi all!
Im trying yo send a gmail with an automation, I want to send an email to a list fo mails which are in a lookup record separated with commas.
I try to do this but the test says that my To field is empty
Some help, pls?
Many thanks
Zack_S
8 - Airtable Astronomer
Here’s a template for you to review. Seems to be working for me with a Rollup and ArrayJoin as the formula.
8 Replies 8
Zack_S
Instead of using a lookup, try a Rollup field.
With ARRAYJOIN(values) as the formula.
Jose_C
Thanks,
it is the same
some other idea?
Did you re-test your trigger step?
Jose_C
yes, i build a new automation, but is the same problem
the field is just emails with commas…
Some idea, sirs?
Zack_S
Jose_C
Many thanks!!
Now it works!
leximaio
Any way someone can let me know how to do this. The above links AND image is not working
I also followed this solution and works for me.
First you need to add field as rollup field. you can find it when you scroll it down when adding a field.
check the table you want to lookup from.
choose the field you want to bring in to the table.
write the formula to the aggregation formula box as ARRAYJOIN(values)
and then, you can go to automation and trigger as you want the conditions to be.
for 'send an email' action choose your newly added rollup field for "To"
I hope you'd already have found the way out.
