I need help from an Expert
Topic Labels: Automations
1881 1
Cristian_Rojas2
Hi!
I’ve been loosing my mind over the past days trying to find a way to either solve this automation or find an alternative even if it requires a manual check.
However it got to the point where I am willing to pay for much needed dedicated help.
Here’s the situation:
Scenario
I have 2 Bases.
  • The first one is a very simple setup on a free plan where collaborators drop basic input: Airtable - Registro de Producciones (that’s it, nothing fancy here).
  • The second base is on a different workspace on a Pro account. I’m using the Sync feature to pull the data onto this Base.
Goal
Part 1
  • Create a new linked record when the field of either “Videographer”, “Photographer”, “Producer” or “Videographer 2” is not empty.
  • Add an Emoji to represent their role (this is very important because of other formulas running behind everything)
Part 2
  • Update records whenever a collaborator modifies the role on free plan base.
Current Situation
  • I’ve managed to trigger the automation to create the new linked record adding the corresponding emoji.
Problem 1
I would appreciate any experts recommendations you could provided. I’m thinking perhaps we can tackle this in a single video call session.
Thank you :pray:
Steph
Airtable Employee
Airtable Employee
Hi Cristian!
Welcome to the community.
Would you be able to provide a screenshot of how you have your automation trigger set up as well as any of your actions?
