Max Field Limit
3882 3
Tara_Bryant
Does anyone know what the max field limit is for each table in each base? Thanks.
Jason
Airtable Employee
Airtable Employee
Hi @Tara_Bryant! There’s currently a maximum of 500 fields per table.
3 Replies 3
I’ve gone well over 100 and never hit any limits or seen any indication of a limit. I’m not sure there is a limit…
Jason
Airtable Employee
Airtable Employee
And if that’s not enough, you’re likely employing a data model that is probably not ideal. :winking_face:
There are some very clever experts in this forum that can help guide you into a data model that takes advantage of Airtable’s linking, lookups, and roll-ups in a way that will result in a scalable and simple architecture and a design that tends to use far fewer fields than you might have determined were otherwise needed.
