Has anyone solved the issue with having more than 50,000 or even 100,000 active records (what I’m told by Airtable is the top paid plan max) that technically need to fall under one base?
I’ve talked to Airtable support and looked around the forums, but haven’t found any solutions. The only thing I can figure is to archive dead or completed records and move them to their own base. However, that messes up our ability to view holistic data sets such as financials over time or to easily slide a record back into the active workflow as is required time to time, and essentially leads to no better a system than many Excel spreadsheets. I’ve thought about it using the API, but with the record limit stemming from Airtable, there’s no way around it besides building our own database. Thanks.
Experts: Solution for more than 50,000 records?
