Problems using typeform - Typeform not accessible
849 1
Xavier_Denis
Since 3 weeks we try to connect to typeform tools & the platform is very slow or even not accessible at all.
Anybody knows sth about this?
Thanks
Miss_Kyra
I also have a problem with connecting typeform to Airtable - I get an error message:
Application error
An error occurred in the application and your page could not be served. If you are the application owner, check your logs for details. You can do this from the Heroku CLI with the command
heroku logs --tail
