Hello all, I have created an AirTable base used for tracking insurance documentation for a construction company. I have set up a date column of when the insurance document in question expires. I was wondering if is possible to set up an automation to send an email to a user that this document is expiring? The issue I run into is that all of the dates are different. I see in the automations you can select "when a record matches conditions" then when selecting a condition when 'insert my expiration column in first field". The next step is where I hit the issue because there is no way to select "date that is listed in the column". Hope this makes sense and there is a different way around it I am just not seeing it. Appreciate anyone who can lend their expertise and I can provide more information if needed. Thank you!😊
Automation help
