63763members
148106posts
Community Activity
Formula If and dateadd
 Hello airtable community, I have this following formula but dateadd does not display the operation in the result thank you for your feedbackFranck IF({Date début package} != '', {Date début package},IF({Date début expl 23} != '', {Date début expl 23...
  • 19 Views
  • 0 kudos
Merging Duplicates
Hi Airtable Community,Hoping you can assist.I'm having trouble merging duplicate records, (Keeping the original record and updating  specified fields from the new record, then deleting the new record once complete).I have no java script knowledge wha...
  • 14 Views
  • 0 kudos
Vee by 4 - Data Explorer
api call
The following bit of code is intended for a Script block to pull data into airtable it was written by chatgpt I cant make this work for the life of me async function updateRDAPData() { let table = base.getTable('Wucy'); // Correct table name ...
  • 22 Views
  • 0 kudos
Using automation to link records
One if the biggest pain points I run into every day with Airtable, is trying to link records automatically.  A {formula field} that needs to feed into {linked field}.  If only there is an easy way to do this, any suggestions? My current solution is r...
  • 32 Views
  • 1 replies
  • 0 kudos
Concatenated text field in automation
We needed a "quick" way to see that a calendar entry was canceled (in the label, which is a text field named "Short Name") without typing it. (We use a check box to "cancel" the event) Forgive me, I'm new. This may not be the most elegant way of doin...
  • 40 Views
  • 1 replies
  • 0 kudos
Experienced Airtable Implementation Specialist at Your Service
Are you in search of a seasoned implementation specialist with a knack for creating efficient automations and user-friendly interfaces? Look no furtherHere's what I bring to the table:Previous Experience at Airtable: As a former implementation specia...
  • 37 Views
  • 0 kudos
Rollup fields, formulas, and nuances driving me nuts
Dear community of people so much smarter than me!I am using Airtable to build a film budget that has a number of fields and formulas that are causing me headaches. Table 1) Budget top sheet (two rollup fields: budget & actuals)Table 2) Budget (above ...
  • 173 Views
  • 1 replies
  • 0 kudos
Airtable Top Contributors | March 2024
Happy Spring, Airtable Community, and welcome to the March edition of our Top Contributors post! Each month, we love to shout-out the incredible individuals in our community who go above and beyond to help others excel in their Airtable journey. Our...
  • 43 Views
  • 2 kudos
Editing Comment Notification Email
Is it possible to edit the email notification that is sent out when you @ a specific user?For context;  as our purchase order moves through various stages, the access to those stages is dynamic.  When a user a elevated stage access comments at a user...
  • 36 Views
  • 1 replies
  • 0 kudos
Update records from google sheet
Is there anyway to generate an automation that updates field records within a table by matching values in a different column, similar to an Index/Match function, between AirTable and Google Sheets? Essentially, my team manages IRB protocols and we ne...
  • 35 Views
  • 1 replies
  • 0 kudos
Announcements
Happy Spring, Airtable Community, and welcome to the March edition of our Top Contributors post!  Each month, we love to shout-out the incredible individuals in our community who go above and beyond ...
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
