Using Airtable to document design elements
I’m using Airtable to document design elements. Is it possible to make hex code a field type so that when I enter in a hexcode I can see what color its referring to? Slack has something similar where if you send a hexcode it recognizes it as a color and displays it in the message.
I would check out Airtable’s Color Palette app:
