New Features and Templates for Project Management
AlexLama
Forum|alt.badge.img+7
  • 6 replies
Today we're excited to release three new features that will greatly improve Project Management workflows in Airtable. These include a new gantt layout option, date dependencies which work across views and a better way to preview utilization when assigning tasks.
1. Gantt in interfaces
If you ever wondered why we needed two separate views for timeline and gantt, so did we. Gantt is now a layout option within timeline view. This means you can now view and manage dependent tasks within interfaces or anywhere else you have a timeline view, by selecting gantt in the new layout toggle.
2. Date dependency configuration
Powering the new gantt option in timeline is the ability to configure date dependencies which work across all of your views and interfaces. So if you connect two tasks in a timeline view but then edit the dates elsewhere, the dates will reschedule accordingly regardless. This is particularly powerful if you are working with the same data in multiple views for different people.
Key points about date dependency configuration
  • Once you set them up, date dependencies will work in any view or interface.
  • Whenever tasks are rescheduled, a toast will appear allowing you to undo the action.
  • If you end up with invalid dependencies, weā€™ll show a message in the bottom left on the screen. You can click on this to view the invalid dependencies and fix them at the click of a button.
  • If you don't care about dependencies you can still use this feature to set up a start, end, and duration field which are all editable and stay in sync with one another.
3. See who's free when assigning tasks
When assigning tasks, you can preview your team's utilization before and after assigning the task to them, for the given start and end date of that task.
You can set this up for any assignee or resource element which you are already using for utilization elsewhere in your app. All you have to do is select the field and toggle ā€˜preview utilizationā€™.
Coming soon: dynamic filtering
These features allow you to compare utilization when choosing team members, but imagine you also wanted to filter the selection to people who have the required skills, role or team for a task. Very soon we'll be releasing a feature which allows you to filter record selection dynamically, which means the filter can depend on a property of the task you are trying to assign someone to. This feature will not only help with resource allocation but numerous other use cases, such as filtering offices to a given location, or products to a given vendor.
Templates for Project Management and Resource Allocation
We've put together two new templates to make it easier to show how you can use these new features to build compelling apps for your team's workflows. We hope these can help to inspire your own creations (which I'd love to hear about in the comments below).
šŸ‘‰ Project management template
šŸ‘‰ Resource allocation template
dilipborad
Forum|alt.badge.img+20
  • 215 replies
  • February 16, 2024
Hello @AlexLama ,
Wow, As always Airtable new features are looks more promising.
Both of these updates mostly for Project Management.
Will there be video coming soon demonstrating how to use the new Project Management template? For us medium level users, would be extremely helpful. thanks
  • 11 replies
  • February 27, 2024
I love this new template, but am having trouble with the "My Tasks" view in the interface. When I make a copy of the template to use, this view is actually filtered for a dummy user. I can not find a way to dynamically filter so that the actual user looking at the view sees their tasks. I also cannot seem to find a way to add a filter to this page so the any user can filter out tasks that don't apply to them.
Karlstens
  • 601 replies
  • June 8, 2024
@AlexLama- Thanks for sharing this news. I've finally found time to explore recently added Airtable features and have a question on Date Dependencies.
Is there any chance that the Date Dependencies scope may be extended to include a time, down to the hour/minute?
  • June 24, 2024
I have the same question as @Kelly_Rogala above. Did anyone figure out how to fix this?
Lea
  • July 9, 2024
When I first started using project management tools, having a clear Gantt view was a game-changer. It helped me visualize dependencies and deadlines in a way that simple lists couldn't. Integrating Gantt into the timeline view is a smart moveā€”it makes managing tasks and timelines more seamless. Speaking of project management tools, I recently discovered how crucial CRM software can be for streamlining client interactions and sales tracking. https://planfix.com/crm/, for instance, has been a lifesaver for keeping everything organized and efficient. Great tools really do make a difference!
  • November 14, 2024
The "Preview utilization" does not show up for me, and I'm on the paid Business plan.
