Automation email body - embed graphic
Forum|alt.badge.img+8
Is there some reason this code does not work in the Body my automation email?
<img src="{GraphicURL}">
Where GraphicURL is a working URL reference to a remotely hosted JPG graphic image file (.jpg). The image placeholder shows, but the graphic is not being rendered.
Best answer by ScottWorld
It works for me. It seems like you may be typing the word {GraphicURL} into your email, instead of using the blue plus sign to actually insert the contents of the field into your email.
Forum|alt.badge.img+33
  • 8857 replies
  • April 5, 2025
What is the URL of your image? It needs to be a publicly accessible URL that links DIRECTLY to the image itself, not a “wrapper webpage” that is displaying the image, which is the default URL that you would typically get from Google Drive or other cloud hosting services.
  • 16 replies
  • April 5, 2025
Yes, it’s a direct URL address of the image file (not a webpage URL). It works in a browser directly by pasting and navigating to the URL, and is publicly accessible. The image is hosted on our website at Square.
https://www.scootjoe.com/uploads/5/1/3/1/51318977/published/lma-combo-family-logo.jpg?1708215129
This is the URL in our Airtable field. The field is a text field.
Further the underlying HTML of the email itself shows this URL, it’s just not rendering in the email (either viewing with my Mail app on MacOS or directly in GMail).
  • 16 replies
  • April 5, 2025
  • 16 replies
  • April 5, 2025
If I the field type is changed to URL (for the link text), same result.
  • 8857 replies
  • April 5, 2025
