Automation for "done" checkbox
  • November 9, 2020
  • 0 views
I’m fairly new and trying to create an automation so that when I have completed a task, it goes to the bottom of the page, or a separate tab once it’s clicked as “done.” I’ve made a new column with a checkbox, but what’s the process for automating?
Thanks so much!
Kamille_Parks11
Forum|alt.badge.img+25
Sounds like you just want to filter or sort by the checkbox field, it doesn’t sound like you need an Automation at all.
