Automation to convert text timecode string to a duration field
  • October 20, 2023
  • 109 views
Kelly_Vorrasi1
Forum|alt.badge.img+9
Hi All,
I'm trying to use a linked record to pull up the TRT of an asset that's listed out as a full timecode, extract just the hours and minutes and put that into a duration field. I've gotten so far as to pull the hours and minutes but when I set the automation to fill the duration, because it's not reading the text as seconds, it's coming in with the wrong duration. I haven't been able to get datetime_parse to convert the text to time. I can sense there's an easier way to do this that I'm just not landing on but nothing I've tried has worked.
Best answer by Sho
Databaser is the solution.
This formula can also be written this way.
HOUR(DATETIME_PARSE(TRT, "HH:mm:ss;SS")) * 3600 + MINUTE(DATETIME_PARSE(TRT, "HH:mm:ss;SS")) * 60
Databaser
Forum|alt.badge.img+25
  • October 22, 2023
Try this formula
VALUE(DATETIME_FORMAT(DATETIME_PARSE(TRT, "HH:mm:ss;SS"), "HH"))*3600 + VALUE(DATETIME_FORMAT(DATETIME_PARSE(TRT, "HH:mm:ss;SS"), "mm"))*60
This takes the text value from your {TRT as text} and puts it in a date form. Then extracts the hours "HH" (24 hour clock; use "hh" for 12 hour clock), uses "value" to transfer it to a number and multiplies it with 3600 to convert it to seconds. Same principle for the minutes "mm".
Then use an automation of just copy past into your duration field.
Forum|alt.badge.img+24
  • October 23, 2023
Databaser
  • October 23, 2023
Yes, that seems like a nice improvement of my formula 👍
Kelly_Vorrasi1
  • October 23, 2023
These both worked great! Thank you!
