Autonumber script problem
I use an easy airtable script for the autonumber.
The problem is that it works for one table but not for a second or third table. Do you have an idea ? Is there an error? I keep checking but fields and everything seems correct to me.
Thank you for your answer
Mélissa
Best answer by kuovonne
Looks like you have a typo in the table name when you set the input variable. Should there be a space after the emoji?
Forum|alt.badge.img+27
  • 6004 replies
  • May 19, 2022
  • 8 replies
  • May 19, 2022
You’re right @kuovonne ! there was a space after the emoji.
Thank you so much :star_struck:
Have a nice day
Mélissa
