Create Automation Failure with custome script
If I have a custom script as an action in an automation, is there anyway to have a catch or else statement that would create a failed automation notification like there is for the built in actions?
Meaning, how can I set up a notification system if a custom script fails?
Best answer by kuovonne
Yes, throw a JavaScript exception. https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/throw
Forum|alt.badge.img+27
  • 6001 replies
  • January 13, 2023
If you want your script to fail and stop the automation, you can throw an error. Sorry I cannot format the text as code while on my phone.
throw "this is an error to cause the automation to fail"
You might also want to console.log() some key variables to give more info about why you want the automation to fail.
Another option is to have the script use output.set() to indicate the success of the script. Then use conditions to either take any additional actions of the script was successful, or have an email action if the script says it was unsuccessful. You will probably get the email from the automation email action sooner than the email notification about the failed automation. Of course it might be harder to identify the exact run in the history of it doesn’t fail.
  • 11 replies
  • January 13, 2023
Hi, what kind of error should I throw? a js exception?
  • 11 replies
  • January 13, 2023
@kuovonne Can you write out the code now so that I can understand what you are suggesting?
  • 6001 replies
  • January 13, 2023
  • 11 replies
  • January 13, 2023
kuovonne wrote:
Thank you!
  • 8 replies
  • May 23, 2024
I'm having issues getting output.set() to run when I'm throwing an error. Basically, trying to set a field on the record called Status and set it to "Error". But when an error happens, whether I catch it or otherwise, the output.set does not work. In fact, it erases it above.
Is there a workaround to update a record within a script before throwing an error? Specifically within a catch statement, updateRecord doesn't work within those catch statements it doesn't seem.
