"Fields" could not be converted to a string
Hi, im trying to create an automation that will move data from a field with a formula to another tab whenever a trigger is activated, but for some reason, i get this error - “Fields” could not be converted to a string.
can somebody help solve the mystery?
Thanks,
Liran
Best answer by Databaser
Hi @Liran_hamburg
What format type does your formula field has?
Databaser
  • 866 replies
  • July 26, 2021
Hi @Liran_hamburg
  • July 27, 2021
@Databaser Hello!
Problem solved - thanks for the help
datasofi
  • October 3, 2023
I am facing the same issue. Some detail would help. Even years later. Thanks
