An automation of mine that usually runs fine started throwing this error and failing sporadically. It's for a webhook automation that brings in orders from Shopify. In my attempt to isolate the issue, I've deleted every field from my "Create Record" action, except for Name (single line text) field where I attempt to enter the Customer First & Last name, but it still fails. 🤔 🤔 There are no roll-ups on the table where I'm trying to create the records. There are some formula fields on the table, but I'm not trying to write to those fields. Any ideas? The other threads related to this error message in the community forum did not contain an answer.
