Hello!
I have a formula field set to format as a percent in the table. That field is then part of a linked record lookup field in a table that will trigger automation to send emails. I want to share that percentage in the email. However, when I use the lookup field in the body of the email, it only allows me to include the number as a decimal.  Is there a way to get this to show the percentage?
The original formula field formatted as a percent:
The lookup field settings:
The automation's email token:
The result in the email:
Thanks in advance for any help you can provide!
