I’m running into an issue while trying to set up an Airtable automation that links records across two synced tables, but I’m getting the following error
I have done almost the same type of Automation in another base (which is working fine) and the only difference is I am now working with 2 synced tables in Find Records - in the previous one i created it was comparing synced with source/original table
I've tried adjusting field setups (in source as well) for both tables: Sync linked, string fields, lookups, used Trim function
I continue to get filter errors
I can only assume it's because Airtable doesn't like that both tables are synced?
