Is there any limitation for automation?
  • December 21, 2022
  • 8 replies
  • 86 views
Forum|alt.badge.img+16
Hi, I would like to know if there is a maximum number of automation that a base can have or if it can have infinite automations?
Thank you ðŸ˜Š
Best answer by Mohamed_Swella1
Hi @Sara11
The maximum number of automations per base is 50.
Current limits
  • If you’d like, you can add up to 50 automations to a base. It's important to note that automations that are turned off (inactive) still count against this limit of 50 automations
  • Additionally, you can create up to 25 actions in one automation. Adding up to 25 actions in one automation may help if you find yourself getting close to the total limit of 50 automations. Where applicable, an action can use outputs from previous actions in the same automation.
Hi @Sara11
A base can have 50 automations (active and inactive).
You can read more about it here https://support.airtable.com/docs/automations-overview
Hi @Sara11
Current limits
  • 89 replies
  • December 21, 2022
Mohamed_Swella1 wrote:
Hi @Sara11
Current limits
Thank you very much!!
Hi @Sara11
Current limits
Is there a way to upgrade or purchase additional automations? We've maxed out our 50 and need more...
  • August 14, 2023
I second that, we need more automations! We've maxed out clauses where possible and keep running into issues with the 50 automation limit
Good_Ink
  • 8 replies
  • August 31, 2023
More automations please. Having 50 across every plan as the baseline is great but I would be happy to pay for more. As far as I know, 50 is the limit even in the Enterprise plan.
  • 6 replies
  • October 9, 2023
The workaround that I use for the automation limit per base, is that share my data with another base and then I gain another 50 automations.  It's not ideal, but it works. 🙂
Forum|alt.badge.img+7
  • 6 replies
  • October 15, 2023
Definetely to have @dashler78 work on a proposition to offer more automations capabilities with the different plans, or to pay based on usage. Same than for conditionnal and repeting groups, we should be able to combine both, to add tasks after etc... lot of "simple.valuable things" to work on before focusing on AI.
