Showing distance between hotels and nearby attractions
  • June 11, 2022
  • 0 views
I have a base including 900 hotels in different cities.
I have another base including 1200 attractions in different cities.
On the website frontend I’d like to show nearby attractions and distance to the specific hotel.
I don’t have any issues with calculating the distance between 2 locations. I was wondering how I can show only attractions in the same city for a hotel.
Thanks for your help.
Ata
Forum|alt.badge.img+27
  • 6001 replies
  • June 11, 2022
Can you put both the hotels and the attractions in the same base, and then link them together using a linked record field?
Also, what are you using to build your website front end?
