Look Up - Pushes To, but how to get Pulls From column polulated?
Karlstens
Forum|alt.badge.img+20
Been very busy and I suspect I’m going blind with what’s probably (hopefully) a simple data flow. As a picture says a thousand words, my problem is as per below;
I can self link a record to its own table with a lookup field, which in this example I consider that as “Pushes to” - So A pushes to B. But what I’m needing, is another column that tells me the reverse of that relationship, so I can see that “B” is pulling from A - and then even create a filtered view around that very “Pulls From” data.
I’m keen for your thoughts on this, hoping there’s something simple that I’ve missed that will allow this workflow. But I also have access to scripts/automations too if they’re the only way out of this.
Best answer by ScottWorld
See this thread… and be sure to email support@airtable.com about this as well:
Forum|alt.badge.img+33
  • 8806 replies
  • June 22, 2021
Karlstens
  • 601 replies
  • June 23, 2021
Yup, will do, legend!!!
  • March 31, 2025
So this is marked as solved from 3 years ago. But is there a solution, today?
