Airtable as CRM for cleaning business
I'm putting together a website/CRM/internet stuff for a window cleaning business.
I've looked at Jobber and it seems to offer everything we need but at $100+ per month it's pretty expensive. I tried kickserv which is about half the price for the features we need but my cursory exploration has not been impressive.
I love Airtable and I bet the tools have already been developed to make it work. What sites like Jobber do is give an embeddable form that plugs the customer right into the database. They have another form that the worker can use to create an estimate and this of course all gets plugged right into the database. This can all go together and spit out an invoice. These are the main features I need to figure out for Airtable.
Some other parts of the Jobber-type solution are things like CC processing and messaging. These are nice to have but aren't essential as long as the system can provide notifications when certain things happen.
Any suggestions for tools/apps/whatever I can plug into Airtable to accomplish my goals? I'm a developer so I don't mind digging into the API a bit if I need to.
TLDR, I need:
  • Form for new customers
  • Form for estimates
  • Invoicing
Take a peek at interface designer. It allows you to build a customer facing UI/app on top of your Airtable backend. If you don't want form submitters to be paid base collaborators, you can also embed shared form views anywhere or pass links around to the workers.
Hi there! You can use WeWeb as your customer-facing front end. WeWeb has a native AirTable plugin so it is very easy to connect and work with the AirTable data.
  • May 30, 2023
Very interesting, thanks!
  • May 30, 2023
That looks great...
  • May 30, 2023
The problem with this is the pricetag... It looks like a great service but I'm not willing to pay $39+ a month just to build one form.
If all you need is a form then https://www.fillout.com/ is a good and cheap solution.
I was curious whether Airtable handles credit card transactions natively. I’ve read that I need to use Zapier to connect with Stripe or PayPal for payment processing. However, all these integrations seem too complicated, and I'm concerned that without proper knowledge, it’s best not to get involved. Specifically, I’m looking for more integrations or tools that work well with Airtable, particularly at https://pro.aroundwire.com/.
Can someone give me a hand with these integrations?
