Hello!
I have created a student database and while the linking between tables worked as recently as last week, the copy/paste function appears not to work anymore. Specifically, on the ‘Contacts’ table (see screenshot), any time a new record (student) is added, I would like to copy and paste that name into
other columns which link to other tables such that the names show up in those other tables. For example, as seen in the screenshot, I would like to copy and paste the name ‘Kamala Harris’ to ‘Snapshot_link’ such that it shows up on the Snapshot table. However, I’m unable to do so-- I get a ‘Pasting…’ message and nothing happens. Currently the Name field is a formula, but it won’t work even if I make it a single line text.
Page 1 / 1
Hello @Rachel_Dewey!
The behavior you are describing sounds like it could be a bug. You should be able to copy and paste text(even text created by a formula) into a linked record field directly. Even if the record you are linking to does not yet exist-- the pasted text should create a new record in the associated table and paste as expected.
Are you still encountering this problem? If so I’d recommend emailing support@airtable.com directly and they should be able to help further.
