Hi @Anna_Williamson,
Given that I dont have any context on what Table 2 contains, the way you are doing it is the best way.
You can choose to Add a new record in Table 1, so you wont have to open table 2.
HI Mohammad,
Thanks so much for you response.
I’ll provide a little more context.
The base is for content creation, and table 2 functions as a to do list for our writers.
Table 1 is a general list of all content, with a Kanban, and Calendar view.
Table 2 is linked to table 1, but with a status filter so that only records with “Ready for Writer” appear. Because of this workflow, adding records directly into table 2 would bump them down the Kanban in table 1 before they are read.
