I was wondering who could help me determine if AT can be a very good solution for our needs:
- I’d like to populate a table with potential people to contact, sourced by external searches: so manual import or copy or API actions, to be determined. The goal is then for a person to check those records, and either mark them as OK, or discard them as not valuable. I was thinking a dropdown menu, or checkbox, which would trigger an action. If said to be relevant, contacts would go to another table.
Can I then move a qualified prospect to another table, or bd, and hence not keep the original record ?
Is it better to create a table in a separate database, or can I hide 1 table from a database to some people so the view does not get cluttered ?
If we adopt Airtable, I’ll transfer there some specific functions we currently solve with custom (Python) scripts polling our Trello board. I could not find whether I can do the following :
For every record (currently record) that has not had an interaction, trigger an alert (New record in a Reminder table to show an action to be completed ? Draft message prepared there ?)
Based on those criteria, prepare a draft email that gets saved in a IMAP email account ?
I understand a workspace has its own plan so if I buy a pro plan it only applies to 1 space, but I can have many databases in it, each with many tables, provided each db is not over the plan limit ?
Any fear of having the access/use slowing down ? For hundreds of cards in a board I have lag issues with Trello.
Thanks for your input.
