Problem with 2-way sync and duplicates
Lea_Castonguay
I’m having an issue with two-way syncs in Airtable.
I have a Source-A table in a Base 1, which is synced to Base 2. In Base 2, the Target-A table is linked to a B table.
The problem arises when I want to remove duplicates in Source-A: I have no way of seeing whether one of the duplicates is linked to a record in B in Base 2. If I merge duplicates and delete the one that is linked to a record in B, the connection between Target-A and B is lost.
How can I prevent this loss of links?
I tried using the Dedupe extension on the Target-A table, but I got an error saying I don’t have the necessary permissions.
I understand that if Source-A is synced to multiple bases, removing duplicates can be problematic because additional data entered in Target tables isn’t reflected in Source-A.
Is there a better way to handle this situation?
Lea_Castonguay
I thought of one solution to set up an automation that updates a multi-select field in the Target-A table whenever a record is linked to a record in the B table within Base 2.
This multi-select field would indicate in which base the record is linked, allowing users to check and update the corresponding record in the Target-A table before deleting a duplicate, preventing any loss of links.
Will test this and give an update.
Hi Lea
You’re right—deleting a linked record can break connections. One simple step is tagging duplicates instead of deleting them immediately.
Try this:
  1. Add a "Duplicate?" checkbox in Source-A.
  2. Manually mark duplicates, then check in Target-A to see which ones are linked before deleting.
This keeps links safe for now!
If you want a smoother way to merge without breaking links, let’s talk!
