Subtasks - how to create field
  • June 15, 2020
  • 67 views
Forum|alt.badge.img+13
In the Project Tracker template is a field Subtasks. with a list of items and checkboxes. I’d like to create a subtask field from scratch. Unfortunately, it’s not clear, at least not to me, how to do that?
Tia
Best answer by Michael_Lever
Answered my own question.
Delete ‘tasks’ table
1.Add new field to preferred table, any name you like
2. Long Text
3. Enable rich text formatting
4. Click on entry and expand cell (Shift+Space if you like)
5. Put cursor in expanded cell and click
6. On the left hand side up pops a black ‘square’ with paragraph icon
7. Click on square to reveal some formatting tools
8. Checkbox is bottom right
9. Click on checkbox
10. Enter content.
10.1 If content is several lines then I find avoiding new line at the end of each sentence keeps all content for the same checkbox.
11. To view several items, go to top navigation menu select row height extra tall.
  • June 15, 2020
2. Long Text
10. Enter content.
Glad to know that you found the answer you were seeking! If you would, please mark your comment as the solution to your question. This helps others who may be searching with similar questions. Thanks!
