When creating a FORM, is there a way to copy/paste in lots of items into a single select field?
  • November 22, 2023
  • 160 views
khoner01
Forum|alt.badge.img+8
I want to create a "Kudo board" where employees can select from a drop-down list (single select) of company employees they want to give kudos to.
My thought process is I would like to create a form that includes a list of employees' names from a drop-down (single select field) and a long text field, to add the kudos. When they "submit," it will populate a table with the employee name and the kudos received.
If I want to add a  single select field under forms, is there a way to copy/paste in a list of employee names? I don't want to type them out one by one.
Note when you are working directly in a table, you can
However, there does not seem to be an easily way to copy/paste a list of items into a single select field if you are working under "forms."
If anyone knows, it would be much appreciated!
Best answer by Databaser
Why don't you just add them via the gridd view? What am I missing?
Databaser
Forum|alt.badge.img+25
  • November 24, 2023
khoner01
  • November 26, 2023
Never mind you're right! I took a look again because I did what you originally suggested.
Just realized I was driving myself wild looking at another table with duplicate info but the form was connected to a different table (where all the names were populating).
Thanks for the reality check!
Because a form isn't a view/is separate from a view. Information added to a form can populate a grid view once submitted but it does not work the other way around (information added to a grid view can't populate a form).
I am looking for an easy way to copy a list of over 100 names into a single select field under "forms" so people can nominate who they want to award kudos to. (By filling out the form, it will populate the grid. view).
