a.isDirectory is not a function -> How to fix it
I’m trying to init a custom block for my database but i get this following error whenever I launch the command line block init from any github repo.
Initializing block using https://github.com/xavdid/airtable-grouped-chart template
❌ Something failed! Cleaning up...
❌ Error: a.isDirectory is not a function
Do you have any idea how i can fix it please ?
Thanks in advance for your help
BR
Best answer by Taylor_Savage
I would try updating your node version - current long-term stable version is v14.
Hey there - a couple questions for you:
What version of the blocks CLI are you running? block --version
What version of node are you running? node --version
  • March 17, 2021
Hi Taylor_Savage!!
Thx for your reply.
Here are the version :
  • Block version : 0.0.62
  • Node version : v8.5.0
Thanks for your help
  • 35 replies
  • March 17, 2021
  • March 17, 2021
Well done !! Thanks a lot @Taylor_Savage for your help.
Updating my node version fixed it
