API update records doesn't work in postman.. created records does work and get records work to
  • July 6, 2020
  • 4 views
HI,
I read the document : https://airtable.com/appEYx9XUfEttr3Nr/api/docs#curl/table:table%201:update
I just copy and past the code… and i get errors… but getting records or creating records it is working…
I put the api_key as a parameter and in headers both doesn’t work for updating the records…
In the header is put Content-Type: application/json
https://api.airtable.com/v0/appEYx9XUfEttr3Nr/Table%201
  "records": [
      "id": "recwpwzgzp7pTHfMb",
      "fields": {
        "Name": "test",
        "Notes": "test"
      "id": "recjKjPPQqaXh60MH",
      "fields": {
        "Name": "test2",
        "Notes": "test2"
“error”: {
“type”: “INVALID_REQUEST_UNKNOWN”,
“message”: “Invalid request: parameter validation failed. Check your request data.”
Best answer by F_terstal
nvm… i used post and not put… can be closed
  • July 6, 2020
