Noob problems, running a custom app
  • April 28, 2021
  • 69 views
i have set up nodejs and did block run. then i copy the url in App Url field and i get
Can‘t connect to your local app, did you block run ?
https://localhost:9000/ on local comp is working
Best answer by Edmunds_Priede
Brave Shields DOWN is the SOLUTION
  • April 28, 2021
Welcome to the community, @Edmunds_Priede! :grinning_face_with_big_eyes:
Um…what?
  • April 29, 2021
Um…what?
I mean Shields DOWN ! it is Brave bowser security feature
Yep, a firewall of any sorts can block node from reaching the web fairly easily.
