Reddit post and comment karma to airtable
  • January 11, 2025
  • 48 views
Does anybody know or has script you put in extensions and automatically shows post and comment karma on airtable. You need reddit api and airatble api. And a script that i dont know how to write. I would appreciate every help
Best answer by Mike_AutomaticN
Hey @skuks123!
I’m not sure about the Karma, but for posts you can for sure get the posts to an RSS feed, and then use some additional integration to push it to Airtable.
I’ve done smth similar recently. Feel free to reach out via PM!
Forum|alt.badge.img+28
Hey @skuks123!
  • January 12, 2025
@skuks123
You can access the posts in a no-code way by using Make's Reddit integrations.
If you’ve never used Make before, I’ve assembled a bunch of Make training resources in this thread. For example, here is one of the ways that you could instantly trigger a Make automation from Airtable.
