Sender URL for a Received Webhook
  • February 23, 2023
  • 53 views
Hi all,
I'm trying to get the sender's url (within a strip) for an incoming webhook call so that I can response to call only from a specific domain.  I'm wondering how do i do that?  Thanks!
EDIT Feb 24: I also need to get the sender's url for other reasons (such as deciding what the response will be); hence having access to it in the script serves multiple purposes.  Thanks!!!
Best Regards,
H8
  • February 24, 2023
Hi @h892_2 👋
I don't think you can access that info.
Do you control the webhook caller? If so you could add a secret value to the body which your automation looks for before doing its work.
  • February 24, 2023
Here are some ways to address webhook listener security.
  • February 24, 2023
Hi @h892_2 👋
I do not have access to the webhook caller.  If I can't have access to that.  It looks like I will have to setup some other service to "handle" the incoming webhook request first.  THANKS!
  • February 24, 2023
Thanks!  That's helpful to know tor sure.
