Timed out connection to airtable, reason: connect ETIMEDOUT, socket hang up
  • November 12, 2020
  • 20 views
I’m currently trying to clone one airtable into a different airtable. When I run my code, I eventually get timed out after copying anywhere from 100 - 700 rows. Is there anything I can do to ensure I don’t get disconnected to airtable.
await airTS(‘Applicants’).select({
// Selecting the first 3 records in Students:
maxRecords: maxRecords,
view: “All applicants”
}).eachPage(async function page(records, fetchNextPage) {
  await records.map(async function(record, count) {
    var keyValue = count.toString();
    //each page resets count to 0, so count is 0-99
    if (pageCount > 0) {
      keyValue = (pageCount*100+count).toString();
    // GCP Storage CODE
    const bucket = storage.bucket(bucketname);
    var theURL = record.get('Resume');
    var bigtableResumeURL;
    if (theURL) {
      theURL = theURL[0]['url'];
      //create unique file name for gcp on storage and bigtable
      var lastPartOfFileName = theURL.substring(theURL.lastIndexOf("/") + 1);
      var airtableId = theURL.split('/')[4];
      var gcpFilename = airtableId+lastPartOfFileName;
      bigtableResumeURL = 'https://storage.googleapis.com/pave-resumes/' + gcpFilename;
      var request = https.get(theURL, function (response) {
        if (response.statusCode === 200) {
            var file = fs.createWriteStream(gcpFilename);
            response.pipe(file);
            file.on('finish', async function () {
                //console.log('Pipe OK');
                bucket.upload(gcpFilename, {
                    destination: gcpFilename
                }, (err, file) => {
                  //console.log(err);
                    //console.log('File OK on Storage');
                var email = record.get('Email');
                //grab the role from the positions table
                var role = record.get('Role');
                var roleArray = [];
                if (role !== null && role !== undefined) {
                  console.log(keyValue + ': ' + role +" "+ role.length);
                  for (var indexRole = 0; indexRole < role.length; indexRole++) {
                    roleArray.push(positionsDictionary[role[indexRole]]);
                } else {
                  roleArray = null;
                await talentBase('Complete').create([
                  "fields": {
                    'First Name': record.get('First Name'),
                    'Last Name': record.get('Last Name'),
                    'Email': record.get('Email'),
                    'Role': roleArray,
                    'Eligible': record.get('Eligible'),
                    'Resume': [{
                      'url': bigtableResumeURL
                    'LinkedIn': record.get('LinkedIn') ||  '',
                    'Type': record.get('Type') ||  null,
                    'Start Date': record.get('Start Date') ||  '',
                    'Salary': record.get('Salary') ||  null,
                    'Phone': record.get('Phone') ||  '',
                    //'Date Applied': record.get('Date Applied'),
                    'Source': record.get('Source') ||  null,
                    'Priority': record.get('Priority') || null,
                    'Stage': record.get('Stage') ||  null,
                ], {"typecast": true}, function(err, records) {
                  if (err) {
                    console.error(err);
              file.close();
            filesToDeleteLocally.push('./' + gcpFilename);
      request.end();
Best answer by acco
Hey @Draden_Gaffney,
It’s possible you’re hitting request/volume limits? I believe Airtable has an API throttle of 5 requests every second. Perhaps your code is spinning out a ton of requests and getting throttled?
Perhaps the cheapest way to obey the throttle is to just add a sleep before you scan a subsequent page.
Best,
Anthony
  • 23 replies
  • November 17, 2020
Best,
Anthony
