4 Column If / Then Formula Help Please
  • November 19, 2021
  • 48 views
Cole_Wedemeier
Forum|alt.badge.img+13
I have 3 columns that have data, and for any given record, only 1 of those columns will have data. I’d like a 4th column to populate the data that’s in whichever of the 3 columns has data.
Examples:
Column A = Blank, Column B = Blank, Column C = ABC, then Column D = ABC
Column A = XYZ, Column B = Blank, Column C = Blank, then Column D = XYZ
Column A = Blank, Column B = MNO, Column C = Blank, then Column D = MNO
I cannot for the life of me figure out an IF/AND or a nested IF statement(s) that will make this work.
Is this at all possible?
Here’s a snipit of my table where I’d like Interaction ID to handle what Column D in my previous explanation would have.
I appreciate any insight. Thank you!
Best answer by augmented
Hi Cole. I haven’t tried what I’m about to suggest, but I see no reason it shouldn’t work.
Let your formula be…
{[Pre-App] Interaction ID}&{[Partials] Interaction ID}&{[Apps] Interaction ID}
Let us know if that works.
  • November 19, 2021
Cole_Wedemeier
  • November 21, 2021
Why is it sometimes we just feel we have to overcomplicate it? Oh man, this worked perfectly! Thank you so much, @augmented
