Convert phone number column to a string of numbers
  • January 29, 2021
  • 99 views
Hi!
In my base I have a list of my customers by phone number. We are trying to link if they attended a zoom session. I have a script that can link if it find name or phone number matches. Sometimes though customers dial in by phone. Registration reports from zoom provide numbers in a string of digits with a country code at the front.
Ex. (123) 456 - 7890 would show up as 11234567890
For my script to work I need to have the two columns that have the same values. Is there a way to format using formulas either column to make them match. Any ideas?
Gabi
  • January 29, 2021
This might work…
CONCATENATE(“1”,VALUE({Phone Num}))
  • February 1, 2021
This might work…
Unfortunately, VALUE does not recognize phone number fields!
  • February 1, 2021
It worked for me. Try typing the formula in the field instead of copy/paste. I worry that those quotes in my response may be curly. Those are not good.
  • February 1, 2021
I found the issue!!
You are right, VALUE() does work. I was trying to use it formula field that was pulling the info from a lookup. The value operation only works if you have it look to the original phone number field.
