Delete first matching characters in a column
Forum|alt.badge.img+8
Hi all
Is there a way to delete the certain matching characters that might appear in a column? For example I have a column of data (800+ cells) of company names, and 90% of them are prefixed with a 'number' (that run between 1 and 9), followed by a 'period', followed by a 'space'. For example "1. Some Company Name" or "8. Another Company Name".
10% of the data in the column may not have any numbers or spaces, OR some of the company names may not have a 'space' after the 'period' for example "7.Yet Another Company Name" or "And Another Company Name".Amy advice would be greatly appreciated.
Stephen
Best answer by Alexey_Gusev
Use SUBSTITUTE to remove some certain characters pattern
Use REPLACE to remove characters at some certain place in string
In your case, you need to remove 'from start (position number 1) to period (located by FIND)'
REPLACE({field}, 1, FIND('.',{field}), '')
to remove possible space after period, wrap it all in TRIM:
TRIM( REPLACE({field}, 1, FIND('.',{field}), '') )
Alexey_Gusev
Forum|alt.badge.img+23
  • 1122 replies
  • January 27, 2023
Ron_Daniel
  • 104 replies
  • January 27, 2023
The formula for the "Actual Company Name" field is
REGEX_REPLACE({Listed Company Name},"[0-9](. )|[0-9](.)","")
  • 23 replies
  • January 27, 2023
Many thanks @Alexey_Gusev ! Amazing worked a treat.
  • 23 replies
  • January 27, 2023
Brilliant @Ron_Daniel. A nice elegant solution. 'Many' thanks.
