Formula for First Tuesday of the Previous Month
Currently I have a date field called Date, I would like to make a formula that looks at this date and outputs the first Tuesday of the previous month.
Example
{date} - Shows March 13, 2025
Formula - Should show February 4, 2025 (First Tuesday of Previous Month)
I was able to find the 1st date of the previous month utilizing this, but I cannot seem to figure out how to get the first Tuesday.
DATETIME_FORMAT(DATEADD(DATEADD({Date}, -1, 'month'), -(DAY({Date}) - 1), 'days'),"MM/DD/YYYY")
Best answer by kuovonne
You are probably having trouble because you are using DATETIME_FORMAT() which is turning your date into a text string, which makes it difficult to perform additional math on it. If you remove the DATETIME_FORMAT() from your existing formula, you can use it as the {First of Previous Month} in this formula:
I did longer write-up here in Kuovonne's Guide to Airtable, and included a choice of formulas for both calculating the first of the previous month, and the first Tuesday.
  • 5998 replies
  • March 14, 2025
  • March 21, 2025
Hello ​@kuovonne thank you for the explanation, the longer write up was greatly appreciated and solved my problem.
This is what I utilized in the end.
Date Field labelled {Date}
First of Previous Month (Field Name)
DATEADD(
  DATEADD(
    {Date},
    -1 * (DAY({Date}) - 1),
    "days"
  -1,
  "month"
This output the 1st of the month prior
Then I added another field to find the 1st Tuesday.
First Tuesday of Previous Month (Field Name)
SWITCH( WEEKDAY({First of Previous Month}, "Sunday"),
0, DATEADD({First of Previous Month}, 2, 'days'),
1, DATEADD({First of Previous Month}, 1, 'days'),
2, DATEADD({First of Previous Month}, 0, 'days'),
3, DATEADD({First of Previous Month}, 6, 'days'),
4, DATEADD({First of Previous Month}, 5, 'days'),
5, DATEADD({First of Previous Month}, 4, 'days'),
6, DATEADD({First of Previous Month}, 3, 'days')
This outputted the first Tuesday of the previous month.
Thanks again!
