Formula Help - Contingency and nested if/then?
Ok, I am working on a project and have been staring at my formula for quite a while now. Hoping somebody can help me out! Essentially, I would like to combine several fields into one, but include certain fields only when they are filled. Here is my formula:
DATETIME_FORMAT({Clinic Date},‘MM-DD-YY’)
&" “&{Clinic Name + Activity}&” - “&{Blue - Allocated}&” Blue"&", “&{Red Allocated}&” Red “&” , “&{Yellow - Allocated}&” Yellow"&" - HL Provider: “&{HL Provider}&” - ( “&{Lead Team}&” )"
In this scenario, the following are true:
  • Blue, Red, and Yellow allocations are numeric fields that may or may not be filled in on each row. I’d like them to only appear if they have a number greater than 0 populating that field on a given row (otherwise, I don’t need to see it in the formulated text)
  • HL Provider, Clinic Name, Lead Team are all just other fields that I am interested in seeing in the text, and I’ve tried to format it accordingly.
Is there a way to accomplish what I’m looking to do?
Any assistance would be helpful. Thanks so much!
Best answer by Jeremy_Oglesby
Thanks, Jeremy! This is generating a weird output for me. Any ideas on why this might happen?
Here’s my formula:
DATETIME_FORMAT({Clinic Date}, ‘MM-DD-YY’)
& {Clinic Name + Activity}
& IF({Pfizer #1 - Allocated} > 0, {Pfizer #1 - Allocated} & " Pfizer #1" & IF({Pfizer #2 - Allocated} > 0, {Moderna #3 - Allocated} > 0, {Janssen - Allocated} > 0), ", “)
& IF({Pfizer #2 - Allocated} > 0, {Pfizer #2 - Allocated} & " Pfizer #2” & IF(OR({Moderna #3 - Allocated} > 0, {Janssen - Allocated} > 0), ", “))
& IF({Moderna #3 - Allocated} > 0, {Moderna #3 - Allocated} & " Moderna #3” & IF({Janssen - Allocated} > 0, “, “))
& IF({Janssen - Allocated} > 0, {Janssen - Allocated} & " Janssen”)
& " - HL Provider: "
& {HL Provider}
& {Lead Team}
And here’s a sample of the output:
09-19-21 Viva Calle / Yu-Ai Kai’s Akiyama Wellness Center - 80 Pfizer #1TRUE40 Janssen - HL Provider: TM6 - ( Team 7 )
Do you know what happened with the TRUE situation there?
That line needs to be:
& IF({Pfizer #1 - Allocated} > 0, {Pfizer #1 - Allocated} & " Pfizer #1" & IF(OR({Pfizer #2 - Allocated} > 0, {Moderna #3 - Allocated} > 0, {Janssen - Allocated} > 0), ", "))
You were just missing the OR() function. That last IF() with the OR() function is just determining whether or not to show a comma, depending on if there are other dose-allocations to account for after this one.
Hi @Sara_Stahlberg,
You can wrap the conditional segments of your concatenated string in IF() functions to only show them if the conditions hold true.
DATETIME_FORMAT({Clinic Date}, 'MM-DD-YY')
& IF({Blue - Allocated} > 0, {Blue - Allocated} & " Blue" & IF(OR({Red Allocated} > 0, {Yellow - Allocated} > 0), ", "))
& IF({Red Allocated} > 0, {Red Allocated} &  " Red" & IF({Yellow - Allocated} > 0, ", "))
& IF({Yellow - Allocated} > 0, {Yellow - Allocated} & " Yellow")
& {HL Provider}
& {Lead Team}
Hi @Sara_Stahlberg,
& {HL Provider}
& {Lead Team}
Thank you @Jeremy! Unfortunately, this formula wasn’t accepted for me. Let’s try this way. Here are the actual fields that I am working with:
  • Pizer #1 - Allocated
  • Pfizer #2 - Allocated
  • Moderna #3 - Allocated
  • Janssen - Allocated
I want to be able to show, for example:
09-06-21 Airtable Clinic Name - 25 Pfizer #1, 12 Pfizer #2, 10 Janssen - HL Provider: TM9 - (Team 9)
09-06-21 Airtable Clinic Name Test - 20 Pfizer #1, 5 Moderna #3, 20 Janssen - HL Provider: TM8 - (Team 8)
I might have some punctuation off somewhere I’m guessing?
Perhaps… can you post the formula that is failing? I double-checked all the formula syntax in what I posted to you above and it looks sound. If all you are replacing is field names, then it should work.
  • September 6, 2021
@Jeremy_Oglesby
I think you are missing an & in this line before your second IF.
& IF({Blue - Allocated} > 0, {Blue - Allocated} & " Blue" IF(OR({Red Allocated} > 0, {Yellow - Allocated} > 0), ", "))
@Sara_Stahlberg – edited my formula above based @kuovonne’s fix
Thank you @Jeremy_Oglesby ! This works. Now, if I wanted to add another one in here, where would I add it? Let’s say, Green - Allocated
Because of the conditionals to determine whether or not to add a comma after the name, it’s easier to add it to the beginning of the list of conditionals:
& IF({Green - Allocated} > 0, {Green - Allocated} & " Green" & IF(OR({Blue - Allocated} > 0, {Red Allocated} > 0, {Yellow Allocated} > 0), ", ")
& {HL Provider}
& {Lead Team}
& {HL Provider}
& {Lead Team}
Here’s my formula:
& {HL Provider}
& {Lead Team}
Here’s my formula:
& {HL Provider}
& {Lead Team}
  • September 7, 2021
Part of the difficulty with this formula is the logic for having tidy commas between items without any extra commas. Often in situations like this, I find that the extra work involved in managing commas simply isn’t worth the effort and difficulties in maintaining the formula. Instead I put beginning/ending delineators around the list items such as …
09-06-21 Airtable Clinic Name - [25 Pfizer #1][12 Pfizer #2][10 Janssen] - HL Provider: TM9 - (Team 9)
09-06-21 Airtable Clinic Name Test - [20 Pfizer #1][5 Moderna #3][20 Janssen] - HL Provider: TM8 - (Team 8)
This formula is written in my personal style that combines both CONCATENATE and & to make it easier to identify individual items being put together.
CONCATENATE(
    DATETIME_FORMAT({Clinic Date}, 'MM-DD-YY') & " ",
    {Clinic Name + Activity} & " - ",
    IF( {Blue - Allocated} > 0,  "[" & {Blue - Allocated} & " Blue]" ),
    IF( {Red - Allocated} > 0,  "[" & {Red - Allocated} & " Red]" ),
    IF( {Yellow - Allocated} > 0,  "[" & {Yellow - Allocated} & " Yellow]" ),
    IF( {Green - Allocated} > 0,  "[" & {Green - Allocated} & "Green]" ),
    " - HL Provider: " & {HL Provider},
    " - (" & {Lead Team} & ")",
Thank you @kuovonne nd @Jeremy_Oglesby! You both truly saved me with figuring this out!
