How to separate content into separate fields
K_B1
  • 9 replies
We have a list of names and dates, like so
McClelland, David (1820 - 1899)
We would like to separate the dates from the the name, so everything in parentheses would be extracted and moved to a new column.
I know there must be some code for this, but I am not sure what it is.
Help!
Kevin
Hey ​@K_B1!
Rather than using a script for it, I would suggest to use (1) creating a new Formula field, (2) use the formula shown below.
Make sure to replace “Name” with the actual field name where McClelland, David (1820 - 1899) is found.
  FIND("(", Name),
  MID(
    Name,
    FIND("(", Name) + 1,
    FIND(")", Name) - FIND("(", Name) - 1
You’d have the following
Output:
You can now convert your formula field to a Single Line Text field, or copy and paste the values on a different field if that is what you need!
Let me know if this helps :D
Forum|alt.badge.img+27
  • 6001 replies
  • March 26, 2025
There are several different formulas that can extract data. Here is a method that uses REGEX.
Here is a matching formula to get the name by itself.
K_B1
  • 9 replies
  • March 26, 2025
Dear Mike_AutomaticN,
Thanks.  This formula mostly worked, but in about 20 intances (in 3K or so), it produce the following weird errors - see images.
any recommended modification to the formula?
Kevin
K_B1
  • 9 replies
  • March 26, 2025
Dear Kouvonne -
The first REGEX formula did not seem to work. I copied it exactly and changed {name} accordingly, but it generated an error.
The second REGEX formula, to extract the name only, seems to have worked though I am still checking.
Any ideas?
Kevin
K_B1
  • 9 replies
  • March 26, 2025
Dear Mike -
The error noted above seems to be associated with foreign characters that look like this: ē, ō, ū
While the issues is not universal, these are diacriticals associated with Portuguese, Vietnamese, and Japanese names.
K_B1
  • 9 replies
  • March 26, 2025
Ok solved.  It had to do with character encoding.  Fixed.
  • 6001 replies
  • March 27, 2025
Glad you found a solution that worked.
When building formulas, it is helpful to have sample data that encompasses the full range of expected values.
How did you fix the character encoding?
I am curious about my formula not working. Can you share screen shots of the formula as you typed it, the sample data, and the error that you see?
K_B1
  • 9 replies
  • March 28, 2025
I fixed it by manually re-entering some of the diacritical characters. Apparently they were originally copy / pasted into AirTable from Wikipedia and other sites. Somehow they were encoded differently than the rest of the text. I do not know why this broke the formula, only that once I addressed the characters the formula worked.
  • 6001 replies
  • March 28, 2025
Thanks for explaining how manually retyping the characters worked. Manually retyping text helps surprisingly often.
