IF statement for field condition with URL Encoding options
Hi Community,
Appreciate if someone can help comment about this statement as its not working. Thanks.
{Event Type} = ‘Partner Tech Talk’,
CONCATENATE(“URL/YYYYYYYYYY”,"?prefill_id=",ENCODE_URL_COMPONENT({Feedback Key}),
CONCATENATE(“URL/XXXXXXXXXX”,"?prefill_id=",ENCODE_URL_COMPONENT({Feedback Key})
NOTE: I concealed actual URLs - assuming URL/YYYYYY works. In other words CONCATENATE statement works by itself. However, when trying to create IF statement picking the right URL based on Event Type field this doesn’t work.
  • 63 replies
  • April 24, 2020
I tried replicating this but it gave me a link everytime!
Formula (it’s just using dumb test date but it outputted a link everytime):
IF(test3="late",CONCATENATE("airtable.com/","?prefill_id=",ENCODE_URL_COMPONENT({Field 12})),CONCATENATE("airtable.com/?","prefill_id=",ENCODE_URL_COMPONENT({Field 11})))
See
Could you share with dummy data?
  • April 24, 2020
Thanks Aron,
So my syntax is correct then? Event Type field is a multiple choice. Did I use correct quotes ’ ’ vs. " "?
The only difference in your code segment is string logic vs. field object I think.
  • April 24, 2020
Aron thanks for the rapid response! I figured out… I was missing couple of closed brackets :slightly_smiling_face: It works now
